Old 07-09-2009, 04:55 PM   #1
detroiter
detroiter's Avatar
I'm not going to say yes to you about this. I'm going to say HELL YES it's a worthwhile upgrade.
I can't stress to you enough about how different the car will feel based just on "some metal bar". For like an extra 15-20 dollars on that price, you could get an Ultraspeed (I believe that's the brand) rear sway bar which is 5mm thicker than the TRD one. Either choice you make though, the bar will make a massive difference.
Old 07-09-2009, 04:58 PM   #2
YellowJolt
Drives: 2009 Yaris 3dr LB
Send a message via AIM to YellowJolt
Thank you for your reply. So I will definitely feel this improvement with some spirited driving? Did you adjust your tire pressure up at the same time? I forgot to add that my car came with the 15" alloy wheels and the much-maligned Bridgestone Potenza rubber.
YellowJolt is offline   Reply With Quote
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
