Old 07-09-2009, 06:06 PM   #1
b_hickman11
Drives: 08 Sedan
The dryer removes moisture that may have entered the system to protect the compressor.
So....I would assume that the dryer has some type of rating on it, meaning the amount of moisture it can remove out of the air in a given amount of time. With this new mod, more moisture will be present in the line. How do we know that the dryer will do it's job with the extra moisture. It might work for now, but a year from now, or 2, or 3, will it still be able to work correctly or will it break prematurely due to having to work harder?? Anyone have any longterm data?
b_hickman11 is offline   Reply With Quote
Old 07-09-2009, 07:23 PM   #2
toast
Drives: 2007 LB
Originally Posted by b_hickman11 View Post
So....I would assume that the dryer has some type of rating on it, meaning the amount of moisture it can remove out of the air in a given amount of time. With this new mod, more moisture will be present in the line. ?
The drier will trap moisture and debris that entered the system when it was assembled and charged. As the a/c system is a sealed system you will not be getting any new moisture in the lines until a leak develops and then you have a whole new problem... no cooling. If you replace a compressor you change the drier too.
toast is offline   Reply With Quote
Old 07-09-2009, 07:36 PM   #3
b_hickman11
Drives: 08 Sedan
So whats the point of a dryer?? The way you describe it is that once it dries the initial moisture in the air when the AC is used for the very first time, then dryer is useless?
Old 07-09-2009, 07:47 PM   #4
It has the ability to absorb a significant amount of moisture - more than should be in the system from initial manufacturing. Once the system leaks enough to reach atmospheric pressure the dryer will most likely become saturated. Replacing the dryer, when replacing the compressor is important, since you can't easily tell the condition of the dryer and it is cheap in comparison to the compressor.
Old 07-09-2009, 09:45 PM   #5
b_hickman11
Drives: 08 Sedan
So why wouldn't they come up with a machine that dry's out the system at the factory and not install a dryer since the dryer is useless after becoming saturated from the moisture in the lines during installation. Wouldn't that be more green for the economy??
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
