#1 | |
It has the ability to absorb a significant amount of moisture - more than should be in the system from initial manufacturing. Once the system leaks enough to reach atmospheric pressure the dryer will most likely become saturated. Replacing the dryer, when replacing the compressor is important, since you can't easily tell the condition of the dryer and it is cheap in comparison to the compressor.
#3 | |
| A/C Not Blowing Cold Air...among other things | yarisitis | DIY / Maintenance / Service | 38 | 07-28-2016 04:00 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 12:59 PM |
| DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
| DIY: Unlink A/C from Defroster | stran | DIY / Maintenance / Service | 46 | 01-19-2015 09:17 PM |
| DIY Sound Insulation Guide? | qwerty123321 | DIY / Maintenance / Service | 4 | 02-07-2009 02:56 AM |
