Old 07-09-2009, 07:23 PM   #10
toast
Drives: 2007 LB
Originally Posted by b_hickman11 View Post
So....I would assume that the dryer has some type of rating on it, meaning the amount of moisture it can remove out of the air in a given amount of time. With this new mod, more moisture will be present in the line. ?
The drier will trap moisture and debris that entered the system when it was assembled and charged. As the a/c system is a sealed system you will not be getting any new moisture in the lines until a leak develops and then you have a whole new problem... no cooling. If you replace a compressor you change the drier too.
toast is offline   Reply With Quote
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 09:17 PM
DIY Sound Insulation Guide? qwerty123321 DIY / Maintenance / Service 4 02-07-2009 02:56 AM
