Old 07-10-2009, 06:40 AM   #1
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
i don't know if you need all that to be honest... i installed a driveshaft on a bronco with nothing special (that's a tad redneck)-- but don't be afraid to get under there! :D
http://www.yarisworld.com/forums/showthread.php?t=16743
check the third paragraph
or here too:
http://www.yarisworld.com/forums/sho...31&postcount=3
Old 07-10-2009, 08:31 AM   #2
kmf123kmf
kmf123kmf's Avatar
Drives: '09 Black 5DR AT
Thanks for the info! When I finally get my Yaris I'll take a look under the car and see if it seems feasible for me.
kmf123kmf is offline   Reply With Quote
Old 07-15-2009, 08:07 AM   #3
MUSKOKA800
MUSKOKA800's Avatar
TRD Anti-Sway Bar
Don't be timid. I installed mine on the driveway in 20 minutes (including collecting the tools and clean-up afterward. A couple spanners is adequate. A socket set and two spanners even faster. You likely won't even need to lift the car unless you're fat like me. I didn't even remove the wheels although it would have been slightly easier if I had.
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
