Old 07-13-2009, 09:51 AM   #1
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
not to thread jack, but i'm wondering which I should get-- 19mm or 23mm. i don't plan on getting any wider of tires (195/55 series on 15) and am thinking 23mm might end up as too much
Old 07-13-2009, 10:32 AM   #2
YellowJolt
Drives: 2009 Yaris 3dr LB
Send a message via AIM to YellowJolt
I think I'd recommend the 19mm rear bar, considering you are remaining relatively stock (as I am). The 19mm bar seems to be engineered to complement the stock suspension system and really tightens up the overall handling characteristics of the car. Body roll is slowed (and also limited) to an incremental amount and it's very predictable in turns. I chose the TRD unit but it appears there is also a very reasonably priced aftermarket 19mm rear bar out there (read through this thread). I want to add that my car is equipped with the OEM 15" alloys, and your results may be a bit different with the higher unsprung weight of 15" steelies or smaller 14" steelies.
Scott
YellowJolt is offline   Reply With Quote
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD Rear Sway Bar Install ?? bikegerm Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 12-26-2008 01:46 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
