Old 07-19-2009, 09:49 PM   #1
minervamoon
Drives: none
If that's the way it's defined, then yes, it's aftermarket, a separate fob. Damn. You think that's making the difference?
minervamoon is offline   Reply With Quote
Old 07-19-2009, 09:58 PM   #2
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
Mine with the Toyota keyless entry doesn't beep until I put the key in the ignition with the door open.
Old 07-19-2009, 10:02 PM   #3
Probably. For Toyota OEM systems they have a detailed OEM installation manual. For aftermarket ones it's not so cut and dry.
If you received the manual for the one that they installed, take a look at the "programming" section. There may be a simple way to turn off the open door beeping mode.
DIY: Replacing 2-Door Liftback Door Panel Fabric redyaris DIY / Maintenance / Service 25 06-25-2024 01:24 AM
Replaced door panel fabric with perforated leather to match Clazzio seat covers CTScott Cosmetic Modifications (Exterior/Interior) 13 10-03-2011 11:43 PM
DIY: Changing Factory Door Handles and Lock Cover redyaris DIY / Maintenance / Service 10 05-19-2007 05:55 PM
Cannot open the driver door when unlocking from the outside. Rahxephon DIY / Maintenance / Service 10 12-02-2006 09:18 AM
