Old 07-22-2009, 09:49 AM   #1
eii
Rides canyon walls
eii's Avatar
Drives: 1988 RX7 FC 10th AE
Changing the lower control arm didnt help. I see some possible damage on the crossmember, I'm really hoping its not. I'll post pictures of it. Maybe its the shock/strut assembly? I dont know, its probably time to send it to a shop? I wouldnt know where to even begin with that..
OEM Style Wing Spoiler | TRD Axle-Back Exhaust | Megan Lowering Springs (1.5 f/r) | Simota Carbon Charger Intake | Python 871XP Alarm System | Aluminum Sports Pedal | 17x7 +42mm Enkei J10 Black w/ Silver Lip | 205/40 Falken Ziex-912 | NST Lite Crank Pulley Red | 1ZZ-FE Throttle Body | AMK Racing Header
eii is offline   Reply With Quote
Old 07-22-2009, 10:20 AM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
if you jack up the car, you would see what is bent, what is not. But i do not understand how you would have reassembled the whole thing without noticing anything bent?
the diagnostic is pretty simple. If you have camber, the problem is probably the control arm or shock/strut assembly or the ball joint. The ball joint comes with the control arm, this has probably already been fixed when you changed yours.
Official YARIS Wheel & Tire Guide Black Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 403 08-09-2025 11:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
