#19 | |
Audio Junky
Alts usually max out in the 2-3k range. |
#20 |
Audio Junky
if that bat isn't the problem tho... he'll have just started putting wear and tear on a perfectly good bat and essentially thrown some money away.
#21 |
![]() Drives: none Join Date: Dec 2008
@goku87
first off all.. good luck with the battery. second.. what is the rated battery capacity on the Yaris (like 38Ah.. 45Ah???) Test the alternator charging properly: (this is just a quick check, better is an amp-meter with a range of at least 100, so forget small DMM, rather a clamp amp-meter) start the engine turn on every electric load on the car (rear defog, high beams, fan max speed etc) run the engine at about 3000 RPM Battery voltage should be around 14.2 - 14.8 test the battery: (quick check only, to test the battery you would need to do a 20h discharge test) turn all electric loads off, turn the engine off. battery should settle at around 12.5 - 12.9V (give it like 30 min). In case the battery drops right away (in a matter of 1-2 minutes) than you have a more serious problem. watch the voltage of the battery and turn on the parking lights. The voltage should drop instantly to like 0.1 - 0.3V lower. any more than that and the battery is either: a) damaged b) not fully charged If you have fully discharged a standard battery a couple of times, consider replacing it. Batteries nowadays don't take abuse any more (cost reasons) like they did 10 years ago. Yuasa used to make decent batteries. Especially when the temperatures are colder you will figure out a weak battery. BTW, any battery store will check your battery (their testers are somewhat ok and mostly accurate) for free. If you have indeed a damaged battery, consider that a starter battery could loose up to 50% of its rated capacity and still start your engine at warm temperatures. However, slow drains are the killer (like forget to turn off the dome light on a weekend). Keep us posted. Cheers, Mike |
#22 |
![]() ![]() ![]() ![]() Drives: Black HB Join Date: Oct 2008
New symptoms:
Went to my car again to find it wouldn't start. No surprise. I jumped it, and left it running whilst I went to Walmart get some stuff. I came back 45 min or so later to my (still running) car, and got in so I could drive it to my shop so I could check the alternator output. Something compelled me to turn on the hazards, and guess what happened? My dome light dimmed every time the hazards flashed. I'm talking uber hard-core worse than a power-hungry-amplifier-installed-with-a-horribly-insufficient-electrical-system dim. Nothing else was on, not the heater, not the radio, not even the headlights. Then I turned my car off and it wouldnt start again. Not even turning over. No clicking. No dummy lights. Nothing.
So my guess would be that my alt isn't putting out enough to charge the battery and that is what's causing my battery to suck.
#23 |
Hi goku87,
hmm i would say on the contrary. MAybe it is the alternator... however I would still say the battery is dead. So.. did you go the shop to have everything checked out? Any possibility to hook up a battery charger for like 5 hours (not talking about thise jump start packs.. I refer to real battery charger). BTW.. there are other possibilites what could be wrong,... however the alternator would be my third guess. Cheers Mike |
#24 |
now the car is in storage and i am en route to iraq. i'll continue troubleshooting whenever i get back.
#25 |
I took the car into the dealership yesterday finally and they called today saying they needed $400 to pay for putting the car interior back together. When I said I wasn't going to pay that much the guy said I could put it back together for and pay $300 for current labor costs.
Also, they said the extra current draw was caused by the aftermarket gauges i have installed. Which are disconnected... I am seriously going to throat punch someone...
#26 | |
Audio Junky
#27 |
![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Dec 2008
Yep, that's a load of crap. There is no reasonable company that would charge $100 bucks to reassemble the interior, and furthermore if the gauges are disconnected, they have to prove they were ever connected to begin with if they want to deny a warranty repair.
#28 |
So, what exactly are they trying to charge $400 for? Did they replace anything or just spend hours yanking apart the interior (looking for those missing electrons)?
#29 |
Audio Junky
sounds like they fixed his problem... but denied the warranty coverage by blaming the aftermarket guages.... probably because they don't know why it went wrong, and want to charge him cause autosales are low this year... and they figure he'll bend over and take it like most people do.
#30 | |||||
Question/Statement Replies:
---------------------------------------------------- Situation Update: After I picked up my car (and paid $0 for anything) I decided to give them the benefit of doubt on my part in the possibility I had left the guages installed. I remember them being "off" since before I deployed, and when I picked my car up, they were hooked up and working well. So me in my curiosity checked the current draw and of course it was nowhere near the 100mA they claimed it was. And just for $#!+s and grins I completely disconnected the guages; guess what? Battery is dead. How convenient. This was in the concern description box said on my receipt, typos included: Quote:
I'll check what pins I actually have it hooked up to, but seriously, should I get a frigging lawyer on their ass?
#31 |
I think the crack pipe was being passed around in the service bay that day. I would definitely fight it since you paid a significant amount without the car being fixed.
You mentioned that you measured the current draw at <100mA. How did you measure it? Have you actually measured how much current is drawn with the car powered off (using a clamp-on ammeter or pulling the negative battery lead and putting an ammeter between the negative battery terminal and the negative battery cable)? |
#32 | |
The hood release latch beneath the dash is GONE!!!! Seriously, wtf is up with these guys? Now I can't test anything under the hood because their dumb asses are lazy and can't do their job for shit. ![]() ![]() ![]()
#33 | |
#34 |
could someone verify on their yaris the current draw on the battery with car turned off: I'm measuring approx 785mA.
For whatever magical reason, this isn't killing my battery in a few days, but with the guages connected, the extra 90mA will. wtf?
#35 |
I measure just over 300mA with the car off.
#36 |
i wish the dealership wasn't so gay and just fixed my problem without trying to rape my wallet.
| Battery Current Drain | karlb | General Yaris / Vitz Discussion | 3 | 12-09-2008 04:28 PM |
| glowshift gauges combo, DF tanabe spring, + leather boot for sale | cdmyaris | Items for Sale by private party | 19 | 09-28-2007 03:33 AM |
