I used to have more posts
Drives: '10HyundaiTucson'07Impreza Join Date: Jan 2007
You get what you pay for.....
I use the Toyota filter that is recommended. |
I use the dealer filter,its only $8 and i'm sure the engineers at Toyota have done testing to make sure its the optimum filter for the engine. Although there may be better filters out there as all filters are not created equal.Although the study is for a Ford motor it gives some good points to look for when trying to understand whats inside the filter and why i should buy one over another.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html |
#3 | |
#4 | |
I've never seen that. Maybe I'll look into it after I use up these 12 Pennzoil filters.
DWEED
Drives: 3DR 2008 Metorite Metalic Join Date: Oct 2008
[QUOTE=jambo101;365277]I use the dealer filter,its only $8 QUOTE]
Once and a while (twice a year) the Toyota dealers in my area run a mail special. $3.95 each.
Making a decision without following it with an action is still a fantasy. |
![]() ![]() ![]() ![]() Drives: 2006 yaris Join Date: Oct 2008
I use Pennzoil or valvoline in both my cars with oem for the yaris but puralator pure one for the 08crv, since the oem new Honda filters are made by fram. I have read alot of bad stuff on Fram for a while and saw cut filters of a few different brands and fram did look inferior. But what really did it was my neighbor uses fram or motorcraft and about 4 months ago his fram filter failed (seems to have come apart from the inside) and oil spilled everywhere. When he opened the the filter it looked like just a cup just filled with parts. There is a web site called bobistheoilguy.com which cover all this stuff in detail.
#8 | |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| Higher capacity oil filter???? | 2006fronty | DIY / Maintenance / Service | 29 | 01-06-2009 02:00 PM |
| Nippon Oil Filter | IllusionX | DIY / Maintenance / Service | 6 | 12-07-2008 02:00 AM |
| oil and oil filter question.. | marcus | DIY / Maintenance / Service | 27 | 07-11-2007 03:25 PM |
