Old 08-08-2009, 05:45 AM   #1
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
I use the dealer filter,its only $8 and i'm sure the engineers at Toyota have done testing to make sure its the optimum filter for the engine. Although there may be better filters out there as all filters are not created equal.Although the study is for a Ford motor it gives some good points to look for when trying to understand whats inside the filter and why i should buy one over another.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Old 08-08-2009, 10:06 AM   #2
1stToyota
1stToyota's Avatar
Best filter I've ever seen is the filter that came on the Yaris, from the factory, not the replacement found at the dealership...those appear to be good but nothing special. Factory filter looked like a premium Nippon, but with silicone valve, gasket and special construction for the media.
1997 Lincoln Town Car - SOLD
2008 Scion xD
(w/ automatic) - SOLD
2008 Yaris HB - SOLD
Old 08-08-2009, 01:54 PM   #3
Fenrizwolf
I used to have more posts
Drives: '10HyundaiTucson'07Impreza
there is another thread on here that explains the difference in these filters.
Fenrizwolf is offline   Reply With Quote
Old 08-08-2009, 03:28 PM   #4
1stToyota
1stToyota's Avatar
I've never seen that. Maybe I'll look into it after I use up these 12 Pennzoil filters.
2008 Scion xD
Old 08-08-2009, 08:06 PM   #5
nemelek
DWEED
nemelek's Avatar
[QUOTE=jambo101;365277]I use the dealer filter,its only $8 QUOTE]
Once and a while (twice a year) the Toyota dealers in my area run a mail special. $3.95 each.
Old 08-08-2009, 09:46 PM   #6
06silveryaris
Drives: 2006 yaris
I use Pennzoil or valvoline in both my cars with oem for the yaris but puralator pure one for the 08crv, since the oem new Honda filters are made by fram. I have read alot of bad stuff on Fram for a while and saw cut filters of a few different brands and fram did look inferior. But what really did it was my neighbor uses fram or motorcraft and about 4 months ago his fram filter failed (seems to have come apart from the inside) and oil spilled everywhere. When he opened the the filter it looked like just a cup just filled with parts. There is a web site called bobistheoilguy.com which cover all this stuff in detail.
06silveryaris is offline   Reply With Quote
Old 08-10-2009, 12:16 PM   #7
1stToyota
1stToyota's Avatar
Maybe Fram has or is starting to get serious and up their game a bit...this cut-away doesn't look inferior, in fact it looks better than most, and same goes for their P/N for the Scion xD motor; that one looked as good as, maybe even a little better than OEM and WIX, as far as construction was concerned.
2008 Scion xD
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
Higher capacity oil filter???? 2006fronty DIY / Maintenance / Service 29 01-06-2009 02:00 PM
Nippon Oil Filter IllusionX DIY / Maintenance / Service 6 12-07-2008 02:00 AM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
