Old 08-17-2009, 01:47 AM   #1
Tanabe DF210 will be lowest. You can use camber bolts (front) and shims (rear) to get extra tuck if you have any rubbing issues.
what offset are your wheels?
Old 08-17-2009, 09:42 PM   #2
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
40mm.....I called and they said these wheels would fit, will i have any issues with a 40mm offset? Im pretty sure i read the yaris is good with a 40-44mm offset or something like that? So what goes lower, Tein or the Tanabes?
Old 08-18-2009, 08:48 PM   #3
I believe they should work fine with either Teins or the Tanabes. Also keep in mind that the S.Tech's have a higher spring rate in the rear, making for better handling characteristic on a fwd car like our Yaris. The Tanabe's have firmer spring rates in the front.
Old 08-18-2009, 08:53 PM   #4
jekqmb
Awesome thanks for the info guys...Im ordering either one tommorow, i want to see how the car feels at stock height after i pick her up at noon tommorow to see how low i want to go and how stiff i want my springs and say fairwell to my Redline as the dick salesman drives it away......Thank goodness all i have to do is go grab the keys for the yaris and drive off
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Track Suspension id3379 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 85 06-11-2009 05:59 PM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 12:33 PM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 09:26 PM
