Old 08-18-2009, 07:31 AM   #4
MUSKOKA800
MUSKOKA800's Avatar
If you're paying to have the installations done I would suggest you do both the springs and struts/springs at the same time and save big.
However, if you enjoy home wrenching, carry on and enjoy. Just be prepared to do the same work twice up front.
Suggestion: remove the swaybar before starting the rear spring install. Otherwise the rear axle will not drop sufficiently and you'll have a battle removing the old and installing the new springs.
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
Any negative side effects of TRD sway bar? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-09-2009 12:07 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 08:07 AM
