Old 08-18-2009, 09:17 AM   #1
caineroad
caineroad's Avatar
Drives: 06 Yaris HB CE
Originally Posted by MUSKOKA800 View Post
If you're paying to have the installations done I would suggest you do both the springs and struts/springs at the same time and save big.
However, if you enjoy home wrenching, carry on and enjoy. Just be prepared to do the same work twice up front.
Suggestion: remove the swaybar before starting the rear spring install. Otherwise the rear axle will not drop sufficiently and you'll have a battle removing the old and installing the new springs.
Yea, I am planning to have my dealership to do it for me, quoted around $160, good price? And does toyota knows they need to remove my sway bar before installing the spring and shocks?
caineroad is offline   Reply With Quote
Old 08-24-2009, 07:38 AM   #2
MUSKOKA800
MUSKOKA800's Avatar
$160.00 sound like a great price to do all four corners. Get a written quote. That way if the tech isn't aware of the added challenge the swaybar adds and spends extra time learning his trade they can't add charge you for his education.
Old 08-24-2009, 08:13 AM   #3
Brian
Brian's Avatar
I didn't remove my rear sway bar when I installed my springs and didn't have a problem.
Old 08-24-2009, 10:48 AM   #4
MUSKOKA800
MUSKOKA800's Avatar
Following the TRD instructions and only dropping one side at a time (to save brake line tension) I found that the swaybar did it's job perfectly by restricting the differential between the axle position left to right. It didn't allow one side to drop far enough to dis-lodge the stock spring. After removing the second mounting bolt from the bar the axle dropped further and the spring came right out.
Is the TRD rear sway bar a worthwhile upgrade? YellowJolt Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 07-15-2009 08:07 AM
Does the TRD rear sway bar promote tire wear? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 03-29-2009 10:29 AM
Any negative side effects of TRD sway bar? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-09-2009 12:07 AM
TRD rear sway bar...street or race setting? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 02-08-2009 02:26 AM
TRD sway bar and tire wear Cutie Pie #2 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 02-01-2009 08:07 AM
