I didn't remove my rear sway bar when I installed my springs and didn't have a problem.
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Following the TRD instructions and only dropping one side at a time (to save brake line tension) I found that the swaybar did it's job perfectly by restricting the differential between the axle position left to right. It didn't allow one side to drop far enough to dis-lodge the stock spring. After removing the second mounting bolt from the bar the axle dropped further and the spring came right out.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
| Is the TRD rear sway bar a worthwhile upgrade? | YellowJolt | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 07-15-2009 08:07 AM |
| Does the TRD rear sway bar promote tire wear? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 03-29-2009 10:29 AM |
| Any negative side effects of TRD sway bar? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 02-09-2009 12:07 AM |
| TRD rear sway bar...street or race setting? | detroiter | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 02-08-2009 02:26 AM |
| TRD sway bar and tire wear | Cutie Pie #2 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 02-01-2009 08:07 AM |
