Old 08-24-2009, 06:52 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
oh yeah... i read that royal purple gear oil is also rubbish.
Jem_hadar: Walmart have Castrol syntec 75w90.
and if anyone heard of PROLAB, it's made in Canada.. if you guys can get your hands on that, it's a good way to support Canadian economy :P
Old 08-24-2009, 07:08 PM   #2
Lazerdot
Lazerdot's Avatar
Drives: Blazing Blue 08 liftback
Of course I'd like you to go to TruLube.com to check out the AMSOIL gear lube. I'm not sure the cost once all the Canadian issues are factored in. But you'll be getting an exceptional product that will last.
One Year One Oil-AMSOIL at www.Trulube.com TRD Exhaust, Springs and Struts. TRD SSK. NST Underdrive Crank Pulley. Amsoil Dominator 10w-30 Racing Oil, Amsoil DOT4 brake fluid, Amsoil Severe Gear 75w-90 transmission oil, Ultra Racing 23mm Sway Bar, Camber Bolts, R1 Drilled Slotted front Brakes and SS Brake cables from Micro-Image. Orange Konig Daylight 17s, Kumo MXs. Greg@TruLube.com
Lazerdot is offline   Reply With Quote
Old 08-27-2009, 11:29 PM   #3
Jem_hadar
MORDSITH
Jem_hadar's Avatar
Drives: 2007 Yaris Hatchback
Send a message via ICQ to Jem_hadar
And whats the YarisWorld consensus on Castrol 75w90 synth gear oil?
A good product? A good alternative to using the stock gear oil Toyota uses?
Ppl rave about MT-90... is Castrol considered a pretty decent choice too?
(sorry, im completely uneducated when it comes to most things cars... and that includes oils...)
2007 Yaris Hatchback 5 Door LE, Manual, Package B, Bayou Blue Metallic
Jem_hadar is offline   Reply With Quote
DIY: CHANGE MANUAL TRANNY OIL ttufrosty DIY / Maintenance / Service 157 09-07-2018 01:43 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
HELP! Gear Oil change on a sedan CASTREX DIY / Maintenance / Service 15 05-13-2007 04:14 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
