Old 05-11-2007, 06:52 PM   #1
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
HELP! Gear Oil change on a sedan
I just got the Amsoil 75w-90 gear oil for my manual Sedan.
Never change tranny oil before. Where is the plug located? Is it hard to change?? Should I go to a shop or can i do it my self?
Help!
Old 05-12-2007, 12:59 AM   #2
jmjonesey
jmjonesey's Avatar
Drives: Red 2007 Yaris Sedan
Send a message via AIM to jmjonesey
bump
ivannaknow as well
jmjonesey is offline   Reply With Quote
Old 05-12-2007, 02:29 AM   #3
CASTREX
CASTREX's Avatar
Never mine. It was just $8 in a shop close to mi house.
Thanks for all the help!!!
Old 05-12-2007, 05:38 PM   #4
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
Trany Fill & Drain Plug
I would have gotten this up earlier, but have been busy. I hope this is easy enough for you to figure out.
blacksan is offline   Reply With Quote
Old 05-13-2007, 02:12 AM   #5
GuySmily
GuySmily's Avatar
Drives: 2005 Toyota MR2
Here's a picture from underneath an mr2 (mk1), which is the same as on the Yaris:
On our cars we can also fill from on top the transmission, since our 20-year-old transmissions often have stripped/stuck fill bolts. (The shiny hole in the picture)
Be careful because the bolts have very flat heads, so your sockets will have a hard time keeping grip. Some people have ground down the ends of their sockets because the ends of sockets are rounded.
GuySmily is offline   Reply With Quote
Old 05-13-2007, 02:26 AM   #6
drifto
drifto's Avatar
Drives: 07 5spd Yaris LB
Send a message via MSN to drifto
buy some metric snap-on sockets, youll be fine worth every penny
Going from drift to grip...
07 Yaris LB 5spd
AE86 Corolla GTS 5spd
http://microimage.ning.com/
http://www.microimageonline.com/store.html
drifto is offline   Reply With Quote
Old 05-13-2007, 02:28 AM   #7
blacksan
blacksan's Avatar
On our cars we can also fill from on top the transmission, since our 20-year-old transmissions often have stripped/stuck fill bolts.Be careful because the bolts have very flat heads, so your sockets will have a hard time keeping grip. Some people have ground down the ends of their sockets because the ends of sockets are rounded.
All the more reason to pull the plugs and lightly coat them with never seize. The different metals (drain plug vs tranny case) will create a problem after several years.
Old 05-13-2007, 02:32 AM   #8
blacksan
blacksan's Avatar
Several years ago I picked up a socket set (Met Wrench) that grips the flats vs edges on metric and standard that work real dam good! I have a little bit of everything and do like every thing about Snap On, but the price.
Old 05-13-2007, 04:18 AM   #9
CASTREX
CASTREX's Avatar
Thanks for the help.
BTW, changing gears feels so much smoother after the change!
Old 05-13-2007, 04:20 AM   #10
blacksan
blacksan's Avatar
How many miles on the previous lube? Did you go with synthetic? Did you consider a magnetic drain plug?
Old 05-13-2007, 04:46 AM   #11
CASTREX
CASTREX's Avatar
My car has 5K miles. This is my second change, I did the first one at 1K miles with regular oil. Went with Amsoil full syntetic. No magnetic plug. 0w-30 for the engine and 75w-90 for the tranny. You can feel de difference right away!
Old 05-13-2007, 04:49 AM   #12
blacksan
blacksan's Avatar
My car has 5K miles. Went with Amsoil full syntetic. 0w-30 for the engine and 75w-90 for the tranny. You can feel de difference right away!
Yes, yes, I am also a firm believer in Amsoil!!! The only thing I would have done diffrently is gone with 5W-30 in your part of the world. I can't imagine it gets cold enough to take advantage of the 0W-30. What brand of filter do you use?
Old 05-13-2007, 04:52 AM   #13
CASTREX
CASTREX's Avatar
Yep is hot around here. maybe will change to 5w-30 in 6 or 7 months when I change it again.
Used a WIX filter.
Old 05-13-2007, 04:54 AM   #14
blacksan
blacksan's Avatar
Used a WIX filter.
I also use the Wix. As a matter of fact the NAPA Gold series filter is made by Wix and a tad bit cheaper in my area. How many miles do you plan on running before changing oil again?
Old 05-13-2007, 05:04 AM   #15
CASTREX
CASTREX's Avatar
I'm thinking 10K miles per change. I know I know that I can keep it longer... but change it at 10k will help me sleep better.
Old 05-13-2007, 05:14 AM   #16
blacksan
blacksan's Avatar
My family used Amsoil in heavy equipment for years. We just pulled filters and toped off. When that maintenance was performed we also sent of oil sample. With that method oil was only changed once a year.
I really do believe that a new (quality) filter twice a year along with top off your oil you could easily drive your car the average 15K each year with only one oil change. Now, if you wanted to get real fancy and do a double filter setup once each year for filter & oil would be no big deal.
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
My first oil change RogueYaris DIY / Maintenance / Service 41 02-07-2007 08:41 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-08-2006 12:21 AM
