Old 09-12-2009, 11:27 PM   #7
Below are pics of the window and the frame. The glue is unbelievable. This window was harder to cut out than the windshield was. The tool I purchased has an L shaped blade that you insert into the glue and you pull it along. It was extremely hard cutting the wide band of glue with it. After I struggled with removing it I did some research and found that a piece of piano wire is far more effective. I used the piano wire on the windshield and it cut the glue far better.
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
rear corner windows fogging wushumasterku General Yaris / Vitz Discussion 14 01-23-2006 03:09 PM
