Old 09-15-2009, 05:17 PM   #1
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Originally Posted by Penguin Garage View Post
shoot me a PM.
PMing you now.
Old 09-15-2009, 04:32 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
just live with it. the car's crooked to begin with lol
Old 09-15-2009, 04:52 PM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
i guess i didnt notice it being crooked before
Check out my Build thread:
Old 09-15-2009, 04:58 PM   #4
Tamago
Tamago's Avatar
Drives: UZJ100
did you ever ask for any? remember, you actually had the second set of PG spacers in the country, well before the shims were made. you and i have had plenty of discussion on how to fix the problem, you even told me you would look into making the shims locally. why isn't this happening via AIM?
Old 09-15-2009, 05:12 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
No worries, Joel... Just yankin' your chain.
No need for AIM, we talked about this already and we're good.
Old 09-15-2009, 05:18 PM   #6
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
PETERPOOP should chime in to this one, too.
Old 09-15-2009, 05:20 PM   #7
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Question: Will having shims on one side screw with my alignment? Should I add the shims to both sides to even it out?
Old 09-15-2009, 05:43 PM   #8
Penguin Garage
Penguin Garage's Avatar
Drives: Yaris
you'll want camber even on both sides.
Penguin Garage is offline   Reply With Quote
Old 09-15-2009, 10:32 PM   #9
tk-421
tk-421's Avatar
Drives: 5D-07-LB
That's what I thought. Thanks!
Old 05-19-2010, 09:09 AM   #10
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
well is our yarii really crooked on one side...just curious maybe i can order 10mm and 13mm on one side..anyone.
Old 05-19-2010, 09:26 AM   #11
BluYrs
ヴィッツ ドライバー
BluYrs's Avatar
Drives: 2006 3d 1.0 Linea Sol
Seems to be a universal thing. Mine's got the same problem- glad to see I'm not the only one.
The blue one
Old 05-19-2010, 10:14 AM   #12
spookz
JDM yO!
Drives: '09 3dr. 5-spd
Mine is the same, it became more obvious with lower offset rims and spacers installed.. I now run a 10mm and a 5mm spacer.. There is still approximately a 2-3mm difference between sides.. So I probably needed to run a 13mm and a 5mm.. lol
Old 05-19-2010, 10:24 AM   #13
marcus
toyota
marcus's Avatar
i just checked it..it is..the right side sticks out more than the left..wow.got to get me 2 different spacer size..
Old 05-28-2010, 07:35 PM   #14
marcus
toyota
marcus's Avatar
im on to this garm is sending me 2 spacer 1x10mm and 1x13mm. hope i get it sometime next week..
Old 05-28-2010, 07:45 PM   #15
Tamago
Tamago's Avatar
Drives: UZJ100
crooked yarii are crooked
Old 06-21-2010, 02:43 PM   #16
marcus
toyota
marcus's Avatar
confirmed..i did 13mm on left rear and 10mm on right got it to match closer but i believe left rear is 5mm off fr the right.. still rubbing on the right side after a little shaving on the fender work.
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Seat cushion for thigh, center armrest left armrest BMGYaris Cosmetic Modifications (Exterior/Interior) 2 07-03-2009 11:51 PM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
Slightly damaged wheel aucorium Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 12-06-2008 07:06 AM
