#19 | |
--[ FORUM RULES ]--[ SEARCHING TIPS ]--[ EYELIDS PICS ]--[ RBK SPOILER ]--[ BEST/WORST INVESTMENTS ]--
#20 |
did you ever ask for any? remember, you actually had the second set of PG spacers in the country, well before the shims were made. you and i have had plenty of discussion on how to fix the problem, you even told me you would look into making the shims locally. why isn't this happening via AIM?
#21 | |
![]() ![]() ![]() Drives: Yaris Join Date: May 2009
EDIT: this goes for any of our customers who have bought the spacers and haven't gotten shims yet. Also anyone with other brand spacers can still order our Shims if they need a set. :) |
#22 | |
![]() No need for AIM, we talked about this already and we're good.
#23 |
#24 |
やりすぎだ~
PETERPOOP should chime in to this one, too.
#25 |
Question: Will having shims on one side screw with my alignment? Should I add the shims to both sides to even it out?
#26 |
you'll want camber even on both sides.
#27 |
That's what I thought. Thanks!
#28 |
toyota
well is our yarii really crooked on one side...just curious maybe i can order 10mm and 13mm on one side..anyone.
#29 |
ヴィッツ ドライバー
Drives: 2006 3d 1.0 Linea Sol Join Date: Aug 2007
Seems to be a universal thing. Mine's got the same problem- glad to see I'm not the only one.
#30 |
JDM yO!
Drives: '09 3dr. 5-spd Join Date: Oct 2008
Mine is the same, it became more obvious with lower offset rims and spacers installed.. I now run a 10mm and a 5mm spacer.. There is still approximately a 2-3mm difference between sides.. So I probably needed to run a 13mm and a 5mm.. lol
#31 |
toyota
i just checked it..it is..the right side sticks out more than the left..wow.got to get me 2 different spacer size..
#32 |
toyota
im on to this garm is sending me 2 spacer 1x10mm and 1x13mm. hope i get it sometime next week..
#33 |
crooked yarii are crooked
#34 |
toyota
confirmed..i did 13mm on left rear and 10mm on right got it to match closer but i believe left rear is 5mm off fr the right.. still rubbing on the right side after a little shaving on the fender work.
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 01:41 PM |
| Seat cushion for thigh, center armrest left armrest | BMGYaris | Cosmetic Modifications (Exterior/Interior) | 2 | 07-03-2009 11:51 PM |
| Steering Wheel Issue. | Twistoffate0817 | General Yaris / Vitz Discussion | 8 | 01-31-2009 07:38 PM |
| Slightly damaged wheel | aucorium | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 5 | 12-06-2008 07:06 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
