#37 |
#38 | |
AKA Samurai Racer
where is that connector buddy ? i wanna hook it up to my apexi rsm speed wire |
#39 |
Pop the trim from around the speedometer and you'll see two connectors going to the cluster assembly. If your car is left hand drive the connector you want will be on right and if it's right hand drive it will be on the left.
#40 |
AKA Samurai Racer
or should i say where in the car do i find that connector?
#41 |
AKA Samurai Racer
aaah ok ! thx bro !! no other locations for that wire ? like on the ODB2 port? how does the scangauge get speedo signal? cant i somehow hook into that?
#42 |
The ScanGauge gets it via CAN Bus data at the OBD port. If your car has TPMS the speed signal is available there as well. honestly, popping the trim from around the cluster takes no tools and just a couple of seconds.
#43 | |
AKA Samurai Racer
im a little scared to mess up the plastics as i have a heavy had. how does that plastics come off anyway? |
#44 | |
Pull the cluster trim gently at the top, where the seam is to loosen it. Pull the cluster trim along the bottom straight back towards you to free the tabs that go into the top of the radio trim. |
#45 |
![]() ![]() Drives: toyota yaris 2008 hatch Join Date: Nov 2008
This is the one I got
http://www.harborfreight.com/cpi/cta...unction=Search it match my tach and voltmeter |
#46 | |
Also, does it not include a temp sensor of its own? I can't see how a gauage manufacturer would be able to assume that car manufacturers use the same spec temp sensors. |
#47 | |
now for the sensor it only have one cable and you give me two, so i didnt know on wich one to plug it in so i havent test it on any of them yet now i gues that you r familiar with the gauge that i got, is there a extra hole on the car that i can put the sensor that came with it??? i really want this to work men, thanks for your time Last edited by yoxx; 11-13-2009 at 07:29 PM. |
#48 | |
That makes more sense. The more I thought about it, I realized that water temp gauges aren't like tachs, where you can tie them to a standardized signal. As for where to add your gauges sensor, there really isn't an existing extra hole that I am aware of. I believe that there are plates that can be installed under the thermostat housing that give you a place to install the sensor. I've seen people install them in other cars by drilling and tapping. I know that others on here have installed them, So, you might want to start a new thread asking where and how people installed their sensors. |
#49 | |
now let me ask you a question, do you think that if i use one of the line that you told me from the pin 96 (pink) or pin 97 (blue) i think i could try that and see, because i reeeeeeally don't want to drill a hole on my car, and now that i think there must be a line that i can tap into because, on the speedometer there is two light for temp, one light up COOL so when you start the car and the other is the red light that have the signal of hot temp, anyway let me know what you think thank again for the time |
#50 | |
As for the lights, they are illuminated by the cluster's microcontroller, based on data from the ECM (who processes the sensor data). |
#51 | |
thank buddy |
#52 |
![]() Drives: 2014 SE 5dr Join Date: Nov 2009
I want to wire up some aftermarket LED driving lights. I want them to come when the car is in drive. Is there a easy place to connect them? 2010 5 dr HB. Thanks.
#53 | |
C27 is the 9 pin connector on the front of the transmission (by the shift linkage). It has a row of 4 and a row of 5 pins. The center wire (light blue) on the 5 pin row is the "Drive" indicator wire. It will have 12V on it when the shift is in drive. For ground, you can grab a chassis ground, like the ground bolt under the left headlight. |
#54 | |
![]() ![]() Drives: Yaris RUSH HatchBack Join Date: Jan 2009
Hihi, I already tested the wires tat u mentioned in the picture.. The blue wire does give constant 12v and the pink wire should turn on the lights with the door right? I already tested the pink wire by multimeter and it will only give 12v when the door is closed. So may I know what can I do in order to get 12v out when the door is open because I want my led to be on only when the door is open... Thanks... Last edited by charleschia1986; 11-24-2009 at 02:53 AM. |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 04:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 04:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 03:32 PM |
