Old 11-13-2009, 03:18 PM   #1
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
Pop the trim from around the speedometer and you'll see two connectors going to the cluster assembly. If your car is left hand drive the connector you want will be on right and if it's right hand drive it will be on the left.
aaah ok ! thx bro !! no other locations for that wire ? like on the ODB2 port? how does the scangauge get speedo signal? cant i somehow hook into that?
JDMtuner
Import Performance Tuning
www.jdmtuner.co.za
Old 11-13-2009, 03:20 PM   #2
The ScanGauge gets it via CAN Bus data at the OBD port. If your car has TPMS the speed signal is available there as well. honestly, popping the trim from around the cluster takes no tools and just a couple of seconds.
Old 11-13-2009, 03:26 PM   #3
aucorium
AKA Samurai Racer
aucorium's Avatar
Drives: Yaris 2006
im a little scared to mess up the plastics as i have a heavy had. how does that plastics come off anyway?
JDMtuner
www.jdmtuner.co.za
Old 11-13-2009, 03:35 PM   #4
Pull off the two vertical black pieces that surround the radio.
Pull the cluster trim gently at the top, where the seam is to loosen it.
Pull the cluster trim along the bottom straight back towards you to free the tabs that go into the top of the radio trim.
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
