![]() ![]() Drives: toyota yaris 2008 hatch Join Date: Nov 2008
This is the one I got
http://www.harborfreight.com/cpi/cta...unction=Search it match my tach and voltmeter |
#2 | |
Also, does it not include a temp sensor of its own? I can't see how a gauage manufacturer would be able to assume that car manufacturers use the same spec temp sensors. |
#3 | |
now for the sensor it only have one cable and you give me two, so i didnt know on wich one to plug it in so i havent test it on any of them yet now i gues that you r familiar with the gauge that i got, is there a extra hole on the car that i can put the sensor that came with it??? i really want this to work men, thanks for your time Last edited by yoxx; 11-13-2009 at 06:29 PM. |
#4 | |
That makes more sense. The more I thought about it, I realized that water temp gauges aren't like tachs, where you can tie them to a standardized signal. As for where to add your gauges sensor, there really isn't an existing extra hole that I am aware of. I believe that there are plates that can be installed under the thermostat housing that give you a place to install the sensor. I've seen people install them in other cars by drilling and tapping. I know that others on here have installed them, So, you might want to start a new thread asking where and how people installed their sensors. |
#5 | |
now let me ask you a question, do you think that if i use one of the line that you told me from the pin 96 (pink) or pin 97 (blue) i think i could try that and see, because i reeeeeeally don't want to drill a hole on my car, and now that i think there must be a line that i can tap into because, on the speedometer there is two light for temp, one light up COOL so when you start the car and the other is the red light that have the signal of hot temp, anyway let me know what you think thank again for the time |
#6 | |
As for the lights, they are illuminated by the cluster's microcontroller, based on data from the ECM (who processes the sensor data). |
#7 | |
thank buddy |
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
