#1 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
that is what I meant. it is the same as v-tec. and as far as no one else has been able to master this ??? ummm....well yes toyota has |
#2 | |
Vanos is NOT the same as vtec. Valve timing adjustment is wayyyyyy different than valve lift+duration. VVT-i = timing. VVT-li = timing + lift/duration VTec = lift/duration iVTec = timing + lift/duration Vanos = timing |
#3 | |
then what engine is in this currenty available vehicle? ![]()
| yaris and yaris S | Y@R15 | General Yaris / Vitz Discussion | 54 | 09-14-2009 12:40 PM |
| Source code for Yaris Tachometer | metalshark | DIY / Maintenance / Service | 27 | 04-06-2009 12:41 AM |
| Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. | dtbrown | Performance Modifications | 13 | 03-29-2009 04:35 PM |
| Optimal RPM for shifting Gears ? | JapRulezz | Performance Modifications | 8 | 03-07-2009 04:16 AM |
| RPM problem. | rwseattle | Performance Modifications | 7 | 04-03-2007 11:09 AM |
