Bathroom + Laptop = <3
My new subwoofer setup!
Ok i figured i would get this posted when i was done. It's been a long journey with the yaris, but i still kept the stock radio and am looking for a T1809 scion one so i can use the preouts. ANYWAYS lets get to the good stuff.
As some of you may know i had a small box with an MA Audio cheap subwoofer in there powered by a decent Alpine MRP-350. This setup always clipped at higher volumes and higher load, produced a little bass but wasn't enough for me. So instead of buying a new amp i have 2 Boston Acoustic 10.5 4ohm and 2 JL Audio 10W6V2 subs lying around and figured id use one of the Boston Acoustics which was surprisingly light. So i got to work using TinyGiant thread as an idea and a base thread. The box was honestly a bitch to build, but well worth it in the end. Had some snags and lost a drill bit so i couldn't countersink some screws and also had no carpet so i used bubly vinyl. Also use a router to cut and smooth out some handles(so much easier to drop it into place!) Also if making this box like i did with a grill you need to enlarge the top hole to countersink the grill casing, i almost ran out of space on the wood for this as well. Alot of things were close calls and thank god for wood glue and silicone for that. but in the end i think it came out pretty good ![]() So i went in and zeroed out all the adjustments so i can redo them properly, i still need a meter but ill wait for that. started to play with it slightly and i mean none of the knobs are even 1/4 of the settings they can be and this thing slams, i had to get out of the hatch. All of the bass is kept inside of the car with the angle and can also be felt the same when moving vs. parked. ****Cliff Notes****(and can someone resize that damn picture please) You do not need more than One decent 10" subwoofer and a decent amp in this car for over the top bass needs |
Very inventive, grats man
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Give Me Resonance
those cliff notes could be relative lol. waiting for finished pics though
![]() (3) 12" Alpine Type R Subs/Hifonics BXi1208D Hifonics ZXi6.5c / 2006 Kicker ZX350.4 Knu Fleks 1/0 Wiring & In Big 3 Optima Yellow Top Battery/Iraggi HO Alternator Alpine CDA-105, KCA-420i/KCA-121b/KCE-400BT PG TLD22 8V Line Driver |
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
cool man!
Sold the yaris... rocking an 89 vw cabriolet now :) |
Heres a completed pic of it in the car, need to extend wires on the amplifier and find a better location for it the woofer shakes it all over the place :P
Tiny Giant Clothing
vinyl wouldnt be my first choice. but looks like it fits really well :)
hahah its all i had, i need to pull it off when i get carpet and retap some of the screws so they dont show through.
Almost had a fitment problem too, it would be wise to shave a 1/4 inch or so off the box height, it just slid on the spare tire mount! and i also mad the box overall 4 inches less in width for a tighter volume. Youcan use the same method as you would need the wood for the extra cutout, but just move the side pieces in . |
Tiny Giant Clothing
yeah i just use black felt from the craft store. works pretty slick. if you wanted to you could cut out the sides a little more to make those cubbies underneath useable .. .. i've considered doing that myself
thats a good idea, i never even thought of the black felt, but yeah i routered out the handles right above the cubbies just so i can use the handles. I was thinking of routering out a little square so i can recess and drill the amp into the side. so it doesn't just sit there...
Feel free to use my pics if you wanted to show someone how your boxes look with a grill on it. |
First time DIYer
black felt would have been a good idea. i didn't even think about that when i made mine. i went to an upholstery shop and got actual auto fabric. i feel like a dumbass now haha
LED tails - debadged - 17" wheels - LED door handles - Painted Headlights - 30/35% tint - Blue LED Interior - DIY Cruise Control - Python 460HP Alarm - DIY Power Locks - K&N CAI - Lowering Springs |
Audio Junky
stay with the vinyl. Carpet is a bitch to clean.... gets stuff in it and won't ever let go... its like velcro.
#12 | |
Tiny Giant Clothing
the fabric on my box now is actually a thin fleece. but when i make boxes now i use the felt. If i ever redo my box it would be in the felt for sure
Audio Junky
I personally go for the LineX/Rhinoliner look myself... exspensive & only cost effective if you got a buddy that works for the place... or you have about 8 boxes done all at once.
If I'm only doing one box... sand, prime, sand, prime, then a few coats of Duplicolor bedliner spray. Works well... The HT sub has it right now.. and is holding up well, just don't let anybody house sit and try to clean it using a paper towel.... scrubbing with a paper towel leaves lil paper shread all over it... that took forever to clean out. wish they would've just dabbed the mess instead. BED LINER SPRAY THO.... practically indestructable, whenever it gets dirty (which is almost never) you just wipe it down with a towel. |
i love what u did!! wow man, thats exactly what i've wanted to do!! i was thinking a bit different with the sub completly under the floor as to not lose anytruck, how well do u think this would work?also, u used the stock deck right? i was looking at getting a 15inch and amp and leaving stock deck....... i can install them, i cant design them. lol. all i want is a yaris that pounds but leaves me all the truck i already dont have, lol
#15 | |
Tiny Giant Clothing
directions for building the box :) check it out.
| My suspension setup: Breakfast Blend for the angry panda | Tamago | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 57 | 07-26-2010 03:56 PM |
| N/A setup | Maitre_Te_Te | Performance Modifications | 22 | 12-07-2009 03:24 AM |
| Subwoofer Help - HELP ME PLEASE | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 14 | 10-27-2009 11:25 AM |
| Works bell/Nardi quick release steering wheel setup | blacksandiegovitz | Cosmetic Modifications (Exterior/Interior) | 35 | 09-02-2009 05:52 PM |
| Kenwood KSC-SW1 Powered Subwoofer | seriousfun | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 04-02-2007 02:44 PM |
