Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
Brake question
I searched but didn't find anything. Are the sedan and hatch brakes the same in the front? Even the same as the Vitz? Brackets and everything? I only ask because I have been offered a deal on some endless calipers and rotors but they are for the vitz. If they are the same, I plan on picking up a set. They are for performance, but I also want them for the color.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
I cant say for 100 percent certain but most likely so. Easiest way to check is measure the distance between the bolt holes and as the person whos selling them to you to check and see if its the same.
#3 | |
As aftermarket goes upto 302mm DIA and stock is 255.mm dia if you are talking about the echo/vitz then no they are not the same the Echo has thinner calipers and a different offset . |
Well thanks for the response. I was finally able to get on Endless site and this is what I plan on getting.
http://www.endlessusa.com/brakecaliper/4-pot/
#5 | |
![]() ![]() The difference between fiction and reality? Fiction has to make sense. --Tom Clancy |
| The Basics on Brake Upgrades | kngrsll | Performance Modifications | 56 | 03-06-2024 09:50 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 09:24 AM |
| Brake question | xen555 | DIY / Maintenance / Service | 8 | 03-06-2009 06:14 PM |
| Help Needed - Brake Light Question | *MAD DOG* | Cosmetic Modifications (Exterior/Interior) | 21 | 02-08-2009 06:32 AM |
| Yaris/Echo Rear Brake Question | pdarnell | DIY / Maintenance / Service | 2 | 08-21-2007 02:15 PM |
