#1 | |
I found the 82810-52060 DRL module listed in the parts catalog from Japan. I have the wiring diagram for it, as well. It is wired into the car a little bit differently from the one on our US cars. Looking at the wiring diagram, I believe that you can disable the daytime running lights, but still have the headlights function correctly by cutting the blue wire, which is next to the violet wire. After cutting the wire, you would need to tape or wire cap the two ends. If you try it, cut it about 5 cm from the blue connector, to leave enough to reconnect it, if it doesn't work (Although, I am fairly confident that it will work). 2010 EU DRL.jpg |
#2 | |
so i put the blue wire back :( |
OK. Do you have a volt meter? That pin is definitely the one that controls turning the running lights on or off. For the US version of that module, letting that pin float (cutting the wire) works. For your version, if we can measure the voltage from the blue wire to the chassis ground with the engine running and with the headlights off and then with them on, we can figure out if that pin needs to be tied high or low on your module.
#6 | |
but i'm back from holiday i don't know when can i find time to try :( thanks for everything. i'll give information again when i'm done. |
#7 | |
One more quick test you could try is to take the DRL module side of the wire you cut (and then reattached) and connect it to a chassis ground. |
| News : 2007 Toyota Yaris - the little Euro's official arrival | VitzBoy | General Yaris / Vitz Discussion | 9 | 06-06-2017 01:51 AM |
| Toyota unveils 2007 Yaris T-Sport Concept | VitzBoy | General Yaris / Vitz Discussion | 63 | 01-21-2007 04:12 PM |
