Old 01-02-2010, 11:00 AM   #11
Kaya B.
Drives: Yaris
I found the 82810-52060 DRL module listed in the parts catalog from Japan. I have the wiring diagram for it, as well. It is wired into the car a little bit differently from the one on our US cars.
Looking at the wiring diagram, I believe that you can disable the daytime running lights, but still have the headlights function correctly by cutting the blue wire, which is next to the violet wire. After cutting the wire, you would need to tape or wire cap the two ends.
If you try it, cut it about 5 cm from the blue connector, to leave enough to reconnect it, if it doesn't work (Although, I am fairly confident that it will work).
Attachment 30985
thank you. i just cut the blue wire today and nothing changed :(
so i put the blue wire back :(
Kaya B. is offline   Reply With Quote
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
