Old 01-15-2010, 10:14 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
I think the key is to first figure out if the issue is lack of charging or excessive "off" current draw. The charging one can easily be checked out by measuring the battery voltage while the car is running. If it is greater than the voltage when the car is off (and is fairly steady {i.e. not bouncing from 12 to 15 volts}) then your charging side is probably fine.
agreed... without the clamp meter/ammeter tho even a voltage reading of 14.xx doesn't say for sure if the charging is fine.... do toyota shops even carry clamp meters tho?
OP: have you done any mods to the car... anything in which you may have disrupted some wires (such as HID's, stereo, or anything under the dash)?
Auto trans. drain and fill? FochMan DIY / Maintenance / Service 5 01-07-2010 11:41 PM
What electrical polisher do you use? tomato Wash, Wax, Detailing, Exterior Repairs 11 09-01-2009 12:34 PM
Oil drain plug gasket question schleppy DIY / Maintenance / Service 7 04-17-2009 05:35 AM
What trailer electrical connector required? charles nelson DIY / Maintenance / Service 3 01-16-2009 04:51 PM
