#37 |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
There was a great one before, but I think it was lost.
The DIY for removing the steering wheel and airbag was in the DIY for the leather wrapped steering wheel. Someone else made a separate DIY for installing the new stalk. Can't find either thread anymore. |
#38 |
SIPNDEW
man i got fed up with trying to wire all that stuff so i ended up not even using a switch or relay and wiring them to the parking lights. been working fine ever since. doesnt take a load high enough to hurt anything. toyota switch was 89 and relay was 50, so i saved myself a bit of money
#39 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris Hatchback Join Date: Feb 2009
Damn. I guess there's no way to recover/repost the DIY? Kinda new to the whole forum thing.
#40 | |
After that it was as simple as plugging the fog lights into the right pin in the fusebox in the engine bay, plugging the relay in and removing the steering wheel to plug the new stalk in. |
#41 | |
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
#42 |
SIPNDEW
i just didnt get a wiring diagram or any instructions when i ordered them. and i even got the wiring kit from garm but didnt know how to put it all together. oh well, it comes on when i wanted them too anyways so im happy :)
#43 |
Just another bump.
Can anyone verify the part numbers needed for the '09 5-door Liftback? |
#44 |
New headlight stalk w/ fog light switch (combination switch):
84140-52151 or 84140-52150 Fog Light Relay: 90987-02027 or 90987-02012 (Both part numbers are the actually the same relay) Fog Light Shroud (Left): 81482-52260 Fog Light Shroud (Right): 81482-52330 |
#45 |
Found a kit on eBay that is made for the 09/10 LBs:
http://cgi.ebay.com/ebaymotors/ws/eB...m=150401427321 Just purchased a kit after the seller guaranteed that the kit would fit / work w/ my '09 5-door LB. Now, before I go out and order all the other parts anyone know if the part #s have been updated? Again, this is for an '09 5-door LB: New stalk / combo switch w/ fog light switch: 84140-52151 -------------------------------------------------------------- For the Relay, I'm not sure if I need to purchase one. The kit I purchased looks like it comes with one, but anyway I searched ToyotaPartsCheap.com for these part #s: 90987-02027 - I got multiple hits w/ one being listed for the '07 Yaris. The price for the relay is $57.09. 90987-02012 - I didn't get any hits specifically for the Yaris. It was listed for many Toyota models from '07 and earlier and price is only $20.44. ================================================ Finally, on the '09 5-door LB, do you still connect the fog light wires to the same pins in the box in the engine bay (Where the thick red wire is connected)?
#46 | |
That is all correct. As for the relays, both part numbers function identically. One superseded the other. You can find them on eBay for under $10. |
#47 |
Thanks again CTScott. The ebay auction for the fog light kit I purchased shows this picture:
![]() I circled something in red that looks like the relay. What do you think? |
#48 |
#49 |
![]() ![]() Drives: 2010 Yaris 3dr liftback Join Date: Dec 2009
Is there a choice to go with either the stalk with fog controls or the fog lamp switch that comes in the kit?
#50 |
#51 |
If you are using Garms Kit or any Ebay Kit
you need to do the following . and if you want to use the Fog Light Stalk on the Steering Wheel no wiring need s to be done inside the cabin Garms Kit comes with the new relay in the picture and the little Red lead that plugs into the under bonnet fuse box the pics below are what i did to Garms Kit . |
#52 |
Is there any harm in installing parts as they come?
I get the new stalk today and the relay on Tuesday next week. The fog lights are coming from Taiwan so I'll have those in a week or two. I don't want to wait until I have everything so I don't end up with one big install. |
#53 | |
#54 |
There used to be some threads here on YW w/ pictures on removing the steering wheel, the stock stalk and then replacing the stalk w/ a new one. Can't find those threads anymore.
Anyone have links to or have the pics. from those threads? |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 08:01 PM |
| Compilation of Yaris How-tos/DIYs | YarisBueller | DIY / Maintenance / Service | 39 | 04-28-2018 09:47 AM |
| Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 02:18 PM |
| Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 07:46 PM |
| srs / airbag light after head unit install? | KwonSau | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 12-24-2008 03:04 AM |
