![]() ![]() ![]() Drives: 2011 VW Golf TDI Join Date: Oct 2009
Thanks CTScott!! I think I'll probably cut it at the DRL module if it's easier to access there now that I know which to use! Can I use this directly to the bulb or does it need to go through a fuse first (I just don't know where this wire is in the circuit (up or downstream of the fuse))? Or should I just use the blue wire to power a relay and use the relay output (fused) to bulbs?
#2 | |
So, you could use the DRL output directly to your own bulb as the ground, and then feed 12V from a fused feed, like the two headlight circuits. |
| DRL in Yaris from...? | Falconia | General Yaris / Vitz Discussion | 3 | 02-25-2010 01:22 AM |
| Disabled drl and installed hids and now no fogs... | 604yarisrs | Cosmetic Modifications (Exterior/Interior) | 10 | 02-14-2010 12:26 PM |
| HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
| Where is my DRL Module......? Help With HID's | The Architect | DIY / Maintenance / Service | 6 | 05-20-2009 10:21 AM |
| DRL disalbled. | IllusionX | DIY / Maintenance / Service | 0 | 10-22-2008 03:16 PM |
