![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
Just drive normally. The Yaris is smart enough to cut the fuel completely when:
1. The accelerator pedal is at idle position. 2. The transmission is in gear. 3. The clutch is engaged. 4. Engine speed is above 1100 rpm. (I think it's 1100 anyway.) 5. Engine is at normal operating temperature. Your fuel consumption will be zero under those conditions. Not even the normal 0.2 GPH for idling will be used. Search for "DFCO", or "Deceleration Fuel Cut Off". -Steve |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Help! Car won't start... | Toyota Kel | General Yaris / Vitz Discussion | 4 | 03-01-2010 04:44 PM |
| Yaris does not start | jake002 | DIY / Maintenance / Service | 21 | 01-05-2010 08:53 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
