#19 | |
Steals terrorist's lunch
Drives: 2007 Yaris Liftback Join Date: Mar 2007
I'm beginning to sense a pattern here...
- Brian Share the Road I often carry 2 carpool passengers and mountain bikes or snowboards/skis over a 4,500 foot elevation difference. Click the graphic above to see my detailed mileage logs. |
#20 |
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
If you are arguing that a general sense of "I'm being green" is often involved, I would agree. But by the time one gets to things like coasting with the engine off, the game has become more about the numbers than about the green.
-Steve |
#21 | |
What?
I don't get extreme with it. I don't drive slower than the flow of traffic, and generally don't accelerate slower than they typical "slow poke", I don't run red lights, and... what was this thread about? Oh yeah... I don't shut off the ignition in my normal driving. To me, it's far more trouble than it's worth for daily driving. As with many things, there are different levels of "hypermiling". Don't assume that everyone who does it is the extreme example. I do it merely to entertain and challenge myself in some way other than pushing the limits of the car's acceleration and handling ability on the street. Keeps me out of trouble. |
#22 | |
I DO sense a pattern here...
#23 | |
★weeaboo★
![]() My guess is he wants to conserve energy by not having to type out a multi-paragraph reply justifying his passion for conserving finite resources.
#24 | |
I don't know, I drive with the flow of traffic, run 32 psi in my tires, leave my engine running when going down hills, use my accessories, ignore my gas gauge until it's time for a refill and still manage to get between 41-44 mpg...probably close to the average hypermiler w/ their mpg banners in their sigs, at this forum. |
#25 | |
#26 |
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
Nope, It's more like someone in a gunfight with a revolver. While he only has six shots before he has to reload (bump-start the engine), if he can't solve his immediate problem in six shots he really shouldn't be attending gunfights (shouldn't be driving).
#27 |
And just hope that one of your shots isn't a misfire; might just be the last thing you remember.
#28 |
What?
You guys know that you don't lose all braking just because you run out of vacuum assist, right?
The Yaris has a pretty small amount of vacuum reserve, I've run out of assist on the race track a few times and near the end of autocross courses often. It's scary when you're not expecting it, but if you recognize what's happening, it's not a big deal. Just press harder on the brake pedal, the brakes still work. (One of these days I'm going to experiment with removing the vacuum altogether just to see if the consistency of feel is more acceptable to me than the assist cutting out unexpectedly.) |
#29 |
And I hope that you also realize that if you lose your power assist you're brakes aren't nearly as effective. By the time you figure out that you've lost the assist and you'll have to press a lot harder it could be too late. Oh well.
And you lost vacuum to your booster at the track, or are you experiencing brake fade from overuse? |
#30 | |
What?
Pad fade used to happen at the track a lot until I installed brake cooling ducts. |
#31 |
![]() Drives: 2008 Yaris 5spd, 2005 GLI 1.8T Join Date: Aug 2009
On the matter of shutting off your ignition while rolling...I just thought I'd mention that in addition to the stupidity and danger of the act, it's also illegal. And as someone mentioned, when you're in gear, and your foot's off the gas, you're using zero fuel... The injectors turn off, and your wheels keep the engine turning.
#32 |
There. Fixed it for ya.
#33 |
wow.....lol, y do touchy subjects always turn into bit@h fits?
lol, i have somewhat the same question as the OP, whats better for the car, puch start or crank? jsut about everywhere i park, i am capable of rollstarting it (and i dont know if anyone has tried it, but out little yaris, hb atleast, is so light u can push start it yourself, lo0l, me and my friends got a good kick out of it) so what is better in the long run (no one really cars about MPG, jsut for the car itself) and really, this car is so great on gas. i only get a +-30km difference between tanks and thats one tank of WOT (no my car isn't involved in the recall..... i'm jsut a teen) to nbormal driving. i'm so hapy with it
#34 |
#35 |
Roll starting a manual is no different than down shifting. Put it in 1st or 2nd and let the clutch out, don't touch the throttle and the car starts. No electrical energy required.
Plus for the hypermilers out there, you're saving gas because you don't have to regenerate the energy lost in the battery from using the starter.
#36 | |
| yaris won't start, engine truns over but won't start. | zara616 | General Yaris / Vitz Discussion | 16 | 09-05-2021 11:39 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 08:42 PM |
| Help! Car won't start... | Toyota Kel | General Yaris / Vitz Discussion | 4 | 03-01-2010 04:44 PM |
| Yaris does not start | jake002 | DIY / Maintenance / Service | 21 | 01-05-2010 08:53 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
