DAT'S RIGHT I GOTz 2
any how to's to disengage the traction control?
any1 tried ?
any help will be appreciated
Be aware you'll probably disengage your warranty at the same time.
What?
Did you check your owner's manual to see if there is a method to turn it off?
#4 | |
![]() ![]() ![]() Drives: Yaris Join Date: Oct 2008
That said, if you insurance company thinks they are covering a car with traction control, and you get into an accident and they find out you disabled it they can deny you coverage. Although if you can find the proper fuse, blow it and put it back in, and don't post anything on here, they can never prove that the fuse didn't blow during said crash.(I have no idea which fuse would do it, or what else removing said fuse could disable.). |
![]() ![]() ![]() ![]() Drives: 2008 yaris, stripped, red Join Date: Jan 2009
pull e-brake one click
it wont engage the brake but it'll disengage ABS and traction |
Which Yarii have traction control? Mine doesn't.
What?
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
how about using the search feature ?
I wrote up the method, and others have also. |
![]() ![]() ![]() ![]() Drives: 08 3DR 5M Bayou Blue; 09 Fos Join Date: Oct 2008
Traction control on 08 - back off the gO pedal ;)
| DIY Cruise Control FAQ (2006-2010 Yaris) | CTScott | DIY / Maintenance / Service | 468 | 11-19-2024 03:45 PM |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Traction Control ??? | pennystocks | General Yaris / Vitz Discussion | 6 | 09-12-2006 07:14 AM |
