#1 | |
![]() ![]() ![]() ![]() Drives: Yaris HB Join Date: Jul 2007
The cheapest material out there, eDead_45, was not near as effective (if much at all...), the glue was not 'permanent', very minimum mass. It was too thin. But it was extremely clean and easy to apply, and being super cheap, I used it for double and triple layers in the trunk and under the rear seats (large horizontal surfaces). |
#2 | |
![]() Drives: 2007 hatchback Join Date: Feb 2010
How did you deaden the doors? I assume that you used B-Quiet? Did you use other material?
#3 | |
I did not do anything to replace the moisture barrier, because when I opened the door I did not see any evidence of water having ever leaked in there. It was all clean and dry. - After 62,000 miles with harsh winter weather! I also didn't do anything with the plastic door panel itself, other than replacing broken clips/fasteners with new ones (box of 30 cost $15 in a local upholstery store). The plastic didn't seem to vibrate when I had sound coming out of the door speaker. |
#4 | |
Great. I just got all my sound deadening stuff shipped last week. Thanks for the tips.
#5 | |
D.
. CLA 250, 4MATIC |
Well I manage to take a break at Lunch and finished the rear left door. Everything was so fast! compare to the first door.
I started with the front right door, here are some shots!.. .
. CLA 250, 4MATIC |
Ok, I'm almost done with this other project! need to finish the roof and a climbing wall and I'll be all set, to continue working on my car.
. CLA 250, 4MATIC |
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 12:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 07:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 01:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 02:47 PM |
