Old 04-27-2010, 03:09 PM   #1
Mrhiguy
Drives: Paseo
Do you guys think the Final drive could swap over from a c150 to a c160?
Mrhiguy is offline   Reply With Quote
Old 04-27-2010, 03:34 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Not a chance. The F/D is part of the output shaft.
Old 04-27-2010, 03:44 PM   #3
Mrhiguy
Drives: Paseo
But is it possible to pull the gears off the output shaft?
Old 04-27-2010, 03:50 PM   #4
Bluevitz-rs
Absolutely. That's the only way to do the swap.
The reason you can't swap them is because one caries 5 gears, and the other caries 6. Also, the C160 has an 8 bolt diff and the C150 is a 6 bolt. There would be no point in putting in the diff from the C150. It would defeat the purpose of the close ratio 6 speed.
Old 04-27-2010, 03:54 PM   #5
Mrhiguy
Drives: Paseo
The reason for my question is the idea to use the 6 speed as a better daily driver. Because putting in the 3.526 F/D ratio to the c160 would give it a great o/d 6th gear to keep the revs low but still retain a close to stock 1-5.
Exmple: with 205/55/16 wheels
GEAR=------------------1-------2--------3--------4--------5----------6
c160 with 4.5 FD= 14.9 __ 23.1__ 31.9__ 40.6__ 51.6___ 65.3 @ 3000RPM
C160 with 3.5 FD= 19.2 __29.6__ 41.0__ 52.1__ 66.3___ 83.8 @ 3000RPM
c150 stock3.5 FD= 17.1 __31.9__ 46.4__ 62.7__ 71.7 _______ @ 3000RPM
Old 04-27-2010, 04:36 PM   #6
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
With the 3.5 final drive, the engine would be far too low in the revs when cruising at 60 mph and probably use more fuel because of the lack of power available at those revs.
rob323 is offline   Reply With Quote
Old 04-27-2010, 04:45 PM   #7
Mrhiguy
Drives: Paseo
Then just keep it in 5th gear. Here in the states we drive 65-75mph Average even though the speed limits are generally 65-70 mph.
Plus if 3.5 is too low for you. You can get a final drive from a 4 door Echo c150 with a F/D of 3.850.
Tags
6 speed, conversion, gearbox, transmission
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
Xenon-Vision HID Conversion Kit - $120 Shipped/$160 Shipped for Slim Ballast phu@xenon-vision Sponsors Classifieds Area 8 03-06-2009 02:33 PM
