Old 03-25-2013, 09:47 PM   #1
matthvm
Drives: Yaris
I had my 2008 Yaris in for an oil change and door switch recall and they discovered the bolts on mine had broke . 104,000kms on the odometer - the dealer told me it was going to be paid by Toyota
matthvm is offline   Reply With Quote
Old 03-25-2013, 10:38 PM   #2
Hershey
We've had door switches replaced under warranty . The other rear door is sporadic with the dome light lighting . Had it in , but it worked while in the shop . Never fails . No recall here in the States . Not that I'm aware of .
Old 03-25-2013, 10:42 PM   #3
The power window switches are the recall item.
Old 03-25-2013, 11:06 PM   #4
Hershey
Oh , looked like the door switch for the dome light .
Old 12-24-2012, 03:54 PM   #5
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
I don't quite understand it. My Yaris is 2008 with JTDKT vin, but according to the tsb it's not affected as it follows the production change on Shokki plant. How come some the TSB says 2006-2009? Are there some 08s made after some 09s?
And should I trust the tsb?
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 12-24-2012, 04:00 PM   #6
Yury
Yury's Avatar
Another thing, anyone had issues with bolts in the rear wheel arches (not too sure, probably subframe bolts) in front of the wheels? I am seeing some rust on those. Not necessarily a cause for concern as the bolts are intact, just wondering.
Old 12-24-2012, 05:30 PM   #7
yariseggvvti
Drives: Yaris Hatchieback
When I backing up and come to complete stop I hear like metal click noise. Is this due with lower control arm bolts defect. Please advice. Thanks!
yariseggvvti is offline   Reply With Quote
Old 12-28-2012, 02:26 PM   #8
Lafiro
Drives: 06 Yaris Sedan
I have this noise as well. Its actually very loud over some bumps. I just received a ZTU about this in the mail that Toyota will now cover the defect on late 2006 to early 2009 Yaris with up to 7 years and under 100,000 miles. Too bad I am at 117,000 miles.
Also, with the car off, I can push it back and I hear a loud squeaking sound as well! What in the world is this now? Could it be the control arm bolts just moving and producing the same sounds as over bumps? Or this is something completely different?
I also noticed a new noise. Its like a metal on metal vibration when the car gets warm/hot (even now in winter). As long as the car is in Drive and at a stop, it vibrates loud. Same again when first accelerating from a stop or at a low speed. What can this be?
Can someone help me please. I can't figure these out.
Old 12-28-2012, 03:09 PM   #9
The control arm bolts are easy to check. Even if you can't jack it up to take a look, you can at least feel for them. The pictures below shows where the bolts are located and what the bolts runs up through.
With the pushing back sound, if the bolt broke it could definitely be that.
The metallic sound may be from one of the exhaust shields having pulled through the head of the mounting bolt.
Old 12-28-2012, 05:15 PM   #10
bronsin
bronsin's Avatar
Can you just unscrew the bolt, take a look at it, and put it back without disturbing anything?
Or do things go out of alignment when you remove the bolt and its trouble getting it back in?
Whats the socket size?
Thanks!
Old 12-28-2012, 05:18 PM   #11
Thanks!
It is 19mm. You can remove it and reinstall it without issue.
Old 01-08-2013, 12:32 PM   #12
narly charley
Drives: 2010 Yaris "L" 5 Speed
Just got my letter in the mail today. They are doing a 100,000 mile or 7 year coverage for the bolt. I'll take it in when I see that it's starting to go. Damn this salt!!
narly charley is offline   Reply With Quote
Old 01-08-2013, 09:48 PM   #13
nookandcrannycar
Old 02-13-2013, 02:51 PM   #14
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
i might have this issue..anyone in canada/GTA tried to get this done??
If my calculations are correct, when this baby hits eighty-eight miles per hour... you're gonna see some serious shit!!!!!!
"Horsepower is how fast you hit the object. Torque is how far you move that object.."
Old 02-13-2013, 03:34 PM   #15
Yes - You might. For Canada it is TSB3271
Old 02-13-2013, 03:35 PM   #16
marcus
toyota
marcus's Avatar
would it matter if i got over 100k km on this and its almost 6 years old..
Old 02-14-2013, 06:53 PM   #17
bestyaris
Drives: Polar White 4 Dr
Just passed 110k....no........
2007 Yaris Base Sedan
bestyaris is offline   Reply With Quote
Old 02-14-2013, 07:21 PM   #18
NEexpat
Drives: 2009, auto, 4dr LB
This appears to be a simple "replace". Couple of $4 or $5 bolts, breaker bar or torque wrench and a 19mm socket.
Until you shear one off, then forget it....................................thats why I haven't done mine.
Will probably bring it to the dealer for them to do it at some point.
OH, btw the TSB I have on this is 0078-12
Anyone else seen that one?
NEexpat is offline   Reply With Quote
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
