![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
I hope you can use the Pioneer HU in your Yaris, I was not able to in mine; cause I had the integrated stereo in the S model, and when you pull that out you have no supports for a radio, and Metra only makes it for the single din.... :-( Probably have to order quite a bit of stuff from Toyota to make your car accept a double din, I think your okay if you get the cheaper model Yaris with the "factory" radio. Good luck - Ron
#2 | |
![]() Drives: Nautical Blue Yaris S Sedan Join Date: Jul 2007
I do appreciate the warning though.But i bought Metras Double Din trim plates pictured here (which i thought was the support system)---> http://www.amazon.com/Metra-95-8202-.../dp/B000K52CY2 and toyota's oem center bezel (silver outside trim piece) from my dealer. Im i missing something here ? If i cant get this damn pioneer in my car i think im going to !!!!!!! Can anyone else confirm this? Do i need anything else to mount the HU? Also on another note, i think im just going to take metra's smart harness and just cut the universal plug off, and crimp that end of the wires to the harness that the pioneer unit brings. is crimping ok? |
#3 | |
maybe the sheet metal bracket is what N9QGS is referring to as not being present in the integrated radio...(is that even possible)???/
i am seriously going to kill myself if i spent all of this money just to find out i cant install it!! Especially when im getting it delivered tomorrow!!!! Edit: Found this youtube video of the intergrated radio being removed from the yaris and the radio doesnt have a sheet metal bracket around it!!!!! At around 1:40 you can see what im talking about. WHAT DO I DO!!! http://www.youtube.com/watch?v=xySrP...eature=related Last edited by fxny12004; 05-13-2010 at 09:18 PM. Reason: found evidence |
#5 | |
Sedan Radio.jpg |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
What to do? Step 1 DON'T kill yourself.
#7 | |
*loosens noose around neck as i lol at palmers post*, when you say case for the intergrated radio, you mean that there IS a metal piece/bracket that holds the 2 din intergrated radio in place so that the radio doesnt fall on its weight? Meaning that that same case can be detached/unscrewed from integrated radio and attached into my 2 din pioneer HU and use it IN ADDITION to the metra dash kit i purchased therefore not needing any additional parts? I just want to make sure i understood what you were saying. I had seen your post before btw, but then again you were installing a single din unit, so i thought it would be different from my install. But i was using it as a reference for when i was planning all of this. As you can all see i am an idiot when it comes to car electronics, as ive never done this before so i appreciate you guys' patience and help! I am a computer nerd so im willing to trade my knowledge for yours if need be Anyone?? |
| radio wire colors & alarm wire color reference guide | battleversiontc | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 06-06-2023 02:12 PM |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| SCION/Bazooka Powered Sub w/ harness and mounts! | ozmdd | Items for Sale by private party | 7 | 06-24-2010 11:26 AM |
| Quick advice needed on unfinished amp install | GreenSpeed | In Car Entertainment + Electronics (audio / video / alarm) | 15 | 01-15-2009 11:03 PM |
| How exactly does an heavier duty harness work? | IsLNdbOi | Performance Modifications | 5 | 09-26-2006 04:19 AM |
