Old 05-13-2010, 05:34 PM   #7
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I hope you can use the Pioneer HU in your Yaris, I was not able to in mine; cause I had the integrated stereo in the S model, and when you pull that out you have no supports for a radio, and Metra only makes it for the single din.... :-( Probably have to order quite a bit of stuff from Toyota to make your car accept a double din, I think your okay if you get the cheaper model Yaris with the "factory" radio. Good luck - Ron
198K Miles
N9QGS is offline   Reply With Quote
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
SCION/Bazooka Powered Sub w/ harness and mounts! ozmdd Items for Sale by private party 7 06-24-2010 11:26 AM
Quick advice needed on unfinished amp install GreenSpeed In Car Entertainment + Electronics (audio / video / alarm) 15 01-15-2009 11:03 PM
How exactly does an heavier duty harness work? IsLNdbOi Performance Modifications 5 09-26-2006 04:19 AM
