Old 05-16-2010, 02:25 PM   #1
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Flashing Third Brake Light with DIY
I was designing this and ran into one already on the market. The parts would cost me more than buying this so I bought it. It's the latest idea in getting the attention of dizzy drivers behind you. Here's a Link to the site that sells and explains the technology. http://kahtec.com/smart_stop.htm
I got the one with the delay. It flashes the third light 6 times the first time you apply the brakes then stays lit solid. It does not flash them again unless you leave your foot off the brakes for 8 seconds. Then it will flash them when you apply the brakes again.
I also have a DIY in a PDF that you can download to make things easier when installing.
I also put in a switch for my hatch light so that I can turn off the light while I have the hatch open for long periods.
bobolinko is offline   Reply With Quote
Old 05-16-2010, 09:10 PM   #2
Stiv and I were discussing this a couple of days ago. I think it's a great idea, as I've had a couple of close calls with idiots not paying attention. For $21-$29 (depending on the model) the Kahtec one is a good deal. Stiv and I were discussing circuits for total DIY, but by the time you're done you'd be looking at about $15 in parts.
Old 05-16-2010, 09:45 PM   #3
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
this is way cool, I recently saw a car that had this capability, I thought it was an oem thing, and that if I wanted to do it to the yaris i'd have to mess around with some relays or something. It's not at the top of my list of must buys.... but as soon as I get rid of some debt it will be close by.
Old 05-20-2010, 05:25 PM   #4
smell my finger
smell my finger's Avatar
Drives: 2007 Yaris Hatchback
I saw this on a jeep wrangler about 3 weeks back. I was a couple cars back in a different lane and it got my attention. I wonder how many people will hit the car in front of them watching this if they are in a different lane?
smell my finger is offline   Reply With Quote
Old 05-10-2011, 08:18 PM   #5
Meteorite_Marty
I bought mine this week from http://www.kahtec.com/smart_stop.htm
I chose the Blinking Smart Stop Delay Version.
A good video to see it "live" is...
http://www.youtube.com/watch?v=4it-OewHkYo
Thanks for the DYI. I will definitely use it.
Old 05-11-2011, 06:53 AM   #6
henry33
Drives: yaris1.33
is this legal on the roads ?
looks fantastic
henry33 is offline   Reply With Quote
Old 05-11-2011, 10:08 AM   #7
Klink10
Klink10's Avatar
Here in the US it is.
Old 05-11-2011, 11:07 AM   #8
poorsh2
Drives: 2008 yaris hb
I bought one and installed it in the Third light housing. This made it alot easier to wire.
poorsh2 is offline   Reply With Quote
Old 05-20-2011, 09:13 PM   #9
Meteorite_Marty
I like your idea. It would be easy(ier) this way too.
Original DIY works very well.
Old 05-11-2011, 12:31 PM   #10
Klink10
Klink10's Avatar
Poorsh2....Now I like how you did that. Any DIY on your type install? Oh and what model did you end up with?
Never mind I just looked at the pic closer for model type. Old age creeping in.
How in the world did you disconnect the housing from its mounted position? My luck I'd break the fasteners.
Old 05-11-2011, 12:47 PM   #11
BLH
Drives: 2007 Yaris Sedan
Can you verify the one you modified is the LED style. I believe used with the sedan with spoiler and hatchback.
My 2007 sedan has the standard lamp style third brake light housing.
I just popped mine out and the modules description shows it is quite small. I ordered one and think it will fit inside my sedan's housing.
BLH is offline   Reply With Quote
Old 05-11-2011, 01:18 PM   #12
poorsh2
small screw driver pops the plugs right out and a philips head takes the screws out that are under the plugs then pull. Don't worry you can do it
Old 05-17-2011, 08:34 AM   #13
Lil Abner
Drives: 2009 3dr LB Manual
I just did this mod last night. Took me 5 minutes. Very cool find!
Old 05-17-2011, 03:45 PM   #14
Klink10
Klink10's Avatar
Finally got mine in. Took a couple of attempts because I didn't break the wire coating good enough. I also thought I had a defective third brake light so on a whim I called the local stealer. Pray you never have to replace the lamp unit as I was quoted $140.00 to replace. All is well and thanks everyone.
Old 05-17-2011, 08:31 PM   #15
BuildCode
BuildCode's Avatar
Drives: Black 5-Spd Sedan S
Just ordered mine on Saturday, had it on Monday somehow, installed it today!
For the sedans with the LED spoiler, very easy to install it inline inside the trunk hatch, plenty of space to work with.
BuildCode is offline   Reply With Quote
Old 05-17-2011, 08:36 PM   #16
Lil Abner
HA, we are all getting them now. I ordered the "delay" one, and now I'm wishing I didn't. I'm starting to think I want the regular one. I take mostly back roads, so that delay might hurt me. I may have to sell the one I just installed...
Old 05-17-2011, 08:51 PM   #17
Klink10
Klink10's Avatar
You know, I watched it several times and glad I didn't get the delay version. It flashes quick.
Old 05-18-2011, 12:05 AM   #18
toy_toronto
always toyin'
toy_toronto's Avatar
Drives: 2010 5-Dr
This one could be a good alternative option from a price/feature standpoint? ($13.95)
http://www.qkits.com/moreinfo.cfm/MK178
selectable number of flashes: 5 or 10 times
selectable flash repeat interval: always or not within 5-7sec between two brakes
includes shrink tube to cover complete unit
flash frequency: 7 times per second
Specifications:
power supply: 12VDC
max load: 4A
dimensions: +/- 60x30x20mm/2.4x1.2x0.8"
* Things to consider:
1) It's a kit that could require assembly. If you know how to solder you save yourself a few bucks and have the flexibility of blink asap vs. "delay"
2) $15 min order
For the canucks out there, the vendor is located in Kingston, ON.
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
