Old 05-16-2010, 02:25 PM   #1
bobolinko
Bob
bobolinko's Avatar
Drives: Yaris and Scion XD 5 spd BSP
Flashing Third Brake Light with DIY
I was designing this and ran into one already on the market. The parts would cost me more than buying this so I bought it. It's the latest idea in getting the attention of dizzy drivers behind you. Here's a Link to the site that sells and explains the technology. http://kahtec.com/smart_stop.htm
I got the one with the delay. It flashes the third light 6 times the first time you apply the brakes then stays lit solid. It does not flash them again unless you leave your foot off the brakes for 8 seconds. Then it will flash them when you apply the brakes again.
I also have a DIY in a PDF that you can download to make things easier when installing.
I also put in a switch for my hatch light so that I can turn off the light while I have the hatch open for long periods.
bobolinko is offline   Reply With Quote
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 08:24 AM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 06:05 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 04:43 PM
