Old 05-24-2010, 01:04 PM   #11
SpaceShot
SpaceShot's Avatar
Drives: 2008 Yaris 5 speed HB
@STC
I am running 44psi, max sidewall rating in the tires, and have approx 33k miles on the Goodyear rubber. (I run snow tires on a separate set of rims, Dec 1 through Apr 1)
At dealer delivery the tires only had 28psi, and I put them to 32psi at the first fill up. About 2 months later I raised it to 40, and eventually settled on 44.
The ecometer was not yet popular when I bought, so I went with the ScanGuage II.
You can get the ScanGuage for $155 if you look hard. I liked having the 4 readouts which I have set to display: Trip Mpg, Tach, Coolant Temp, and Throttle Position. Keeping the Tach around 2100 or the Throttle around 23, video game style, helps to make the Trip Mpg climb up.
The other advantage to the ScanGuage is that you can set a function to display most any engine condition it can clear some error codes.
SpaceShot is offline   Reply With Quote
Tags
automatic, manual, mpg
Automatic to Manual converts... any regrets?? maramaralula New YARIS Purchase Forum 22 07-31-2011 11:06 AM
Is LSD Automatic & Manual Same? maxgil05 Performance Modifications 4 04-24-2009 11:57 AM
Want opinions automatic vs. manual transmission anik New YARIS Purchase Forum 84 07-10-2007 05:25 PM
Change automatic to Manual Blenjar General Yaris / Vitz Discussion 11 06-14-2007 07:02 AM
Manual vs. Automatic ?? YarisBlazer General Yaris / Vitz Discussion 12 08-13-2006 08:14 PM
