Yes - Instead of of connecting the wire from pin 4 to pin 13, connect it to pin 11 (which is a white wire with a black stripe). Then, it will turn on with or without the headlights.
CT thats what I want to do. I want to be able to turn on the fogs when I want should I follow this quote and forget what you had sent to me? Holla my dude.
Yes. To make it easier for tapping the wires together (so you are tapping same sized wires together), connect the wire from pin 4 to pin 7 (the smaller white wire with a black stripe, 3rd from the right in the picture above).
Ok, with this then I will be able to turn on & off from the stalk switch correct? And thanxs again my dude.
Alright, I tried that option, and the HID was making noise, and the plug wasnt plug in so I put back the wire the way it was, maybe I connected the wrong wire, but you said the the third wire to the right (white with a black line), I heard that noise and just put back the wire. If you have a option that I can run with holla, and if possible with a pic of the harness with plug and the right wire to use. Please hit me up when you can thanxs.
#7 | |
The plug definitely needs to be plugged in, other wise things are floating, and that might be why your HIDs were clicking. the connection point is the 3rd from the right. |
Post count means nothing.
Drives: AW11, NCP91, Old Motorcycles Join Date: Jul 2006
Thanks for all of the info, so just to clarify...I should connect the wire from pin 4 to pin 7 and NOT pin 11 like in the earlier post? I have HIDs in my foglights as well. The kit that I used has a connector on the relay harness that plugs into one of the foglight plugs that the bulb normally plugs into (doesn't matter which) and then power is tapped from the battery with a ground wire connected. The HID bulbs are connected tot he ballasts which are connected to the relay harness. I hope that wasn't too confusing lol.
#9 | |
Either 7 or 11 should work. They are both grounds. The reason I recommended 11 over 7 is that the wire is the same gauge as 4, so tap splicing is easier. |
Well I tried and the plug was connected and the HIDs were clicking, my option and Brians as well, is to use the cables set to the the projector fogs, it is very easy to install and it has a switch for the function, I really wanted to use the stalk switch but this what I need to do. With this I can turn on the fogs when I want with no hassle, thanxs CT and thanxs brian, I told you that I would use you option or opinion. Thanks to all. Holla at your boy.
#11 | |
| DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
| Sorry! Another fog light question. | Jrilla | DIY / Maintenance / Service | 4 | 08-23-2009 02:25 PM |
| Question about Yaris 2009 fog light? | JAyala | Cosmetic Modifications (Exterior/Interior) | 0 | 02-07-2009 03:51 PM |
| fog light lens question? | Adriaan | Cosmetic Modifications (Exterior/Interior) | 0 | 04-13-2007 11:30 AM |
| question on Fog light | clfile | Cosmetic Modifications (Exterior/Interior) | 6 | 11-09-2006 07:11 PM |
