Old 07-24-2010, 09:28 AM   #1
detroiter
detroiter's Avatar
Easiest performance mod you could do to your Yaris. The 23mm is a bit thicker so it's going to tighten up things a bit more as far as handling goes (keeping the body roll flat). I'd say with the 23mm that while possible to do, have a friend on hand to help fit it on one side while you get the other. Mine anyways, was a very close fit for where you install it, so it helps to have another hand to line it up.
It's not hard to put on at all though. 4 bolts and your done! The difference it makes is quite surprising, especially the 23mm.
Old 07-25-2010, 03:26 AM   #2
yaris4062007
Drives: 07 BB yaris / 06 Mustang Gt
thanx , will be buying 23mm soon :)
yaris4062007 is offline   Reply With Quote
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Question about Spring rate window_lee Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 10-20-2009 04:22 PM
Spring question? jekqmb Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 08-19-2009 06:54 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 10:11 AM
spring rates question botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 05-11-2009 12:33 PM
