Old 10-01-2010, 03:06 PM   #24
Originally Posted by Kaya B. View Post
Thank you Scott. I'll just try. because if it doesn't work i won't pay for other parts. But if it works i have to pay about 100$ so I need some time :)
I will give you info. Thanks for your helps.
Start by measuring the voltage on pin 40 of connector A21 on the ECM, with the ignition on, but the engine off. If it measures 12 V, then it it worth a shot, if it doesn't, then stop there.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
