Old 10-01-2010, 04:31 PM   #26
Since you are willing to experiment and put some money into trying to get cruise control on your car, another option, which I believe will work on the European Yaris, is the Rostra aftermarket cruise control kit.
It is quite a bit more work to install, but it overrides the gas pedal signal itself, rather than requiring that the ECM do that. The European Yaris uses the same 6 pin connector on the accelerator pedal, with the same pinout as the US one, which is why I think that this should work.
There are two versions for the Yaris - An A/T kit ($209) and an M/T kit ($249)
http://www.thecruisecontrolstore.com...g/X380183/0003
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 468 11-19-2024 04:45 PM
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 10:22 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 07:29 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 04:55 PM
