Old 10-03-2010, 03:13 AM   #1
djct_watt
Drives: 2010 NCP91 5spd
Excessive toe out on an overloaded tire at a high roll angle = excessive rotation = oversteer.
djct_watt is offline   Reply With Quote
Old 10-07-2010, 04:06 AM   #2
ddongbap
So now you're going to the extreme. Might as well throw in bald tires into that mix then.
Might as well compare that to a RWD Yaris, on 195s, with 2000 hp.
Or lets just have a semi t-bone the rear quarter panel.
Thats some oversteer right there.
Old 10-07-2010, 04:13 AM   #3
djct_watt
I dont understand your point...
This is exactly what the bar does, "Yo." It does little in roll reduction (on its own) and only helps to increase toe with increased roll, which prematurely overloads the tire, which creates excessive rotation, which can lead to oversteer.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 05:25 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 06:07 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 07:20 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 01:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-05-2008 11:37 PM
