Old 10-14-2010, 08:42 PM   #1
Murtaza_murti
Drives: Toyota Belta
!! Speedometer Needle Problem !!!
I was playing with the speedometer needle while i opened the cluster guages cover for cleaning, when i placed the needle back to 0 after driving i noticed it went below the 0 reading. Now I've heard from someone that the best thing to do is to take out your Cluster guages wire plugs and fix the needle back to 0 and plug the wires back in and the problem will be fixed, I'm scared of doing it because I think taking it out would cause some big mishap so, can anyone tell me if it's ok to do that ? And will my speedometer's reading be effected in anyway ? Thanks.
Murtaza_murti is offline   Reply With Quote
Old 10-15-2010, 03:13 AM   #2
A1phazu1u
A1phazu1u's Avatar
Drives: Black 07 Toyota Yaris Sedan
what you have to do know is open it back up.
Spin the needle to the right untill you feel some resistance and push a little further.
then spin the needle back and you should feel some resistance before you hit zero.
push it till its exactly at zero. you may hear clicking, but don't worry its not breaking.
A1phazu1u is offline   Reply With Quote
Old 09-07-2011, 12:43 AM   #3
Murtaza_murti
Well, I tried that but no luck.
Can somebody else help?
Old 10-15-2010, 06:33 PM   #4
Murtaza_murti
^So there isn't any need to plug out the wire's ?
Old 10-28-2010, 04:53 AM   #5
A1phazu1u
A1phazu1u's Avatar
i don't think so, this is what i do and i've messed with a handful of speedos.
Old 09-07-2011, 06:40 AM   #6
Move the needle to zero with the ignition on. The speedometer is little servo motor, and if you watch it, when you power on the cluster the needle moves a tiny bit, so if you adjust it after it calibrates itself, the needle will be in the correct position.
Old 09-13-2011, 06:41 AM   #7
Murtaza_murti
Thanks for the reply, I'll try it out and let you guys know.
Old 09-15-2011, 01:52 AM   #8
Murtaza_murti
Sadly it didn't work, I tried it twice.
Old 09-17-2011, 09:33 PM   #9
Murtaza_murti
@CTScott, any other solution?
Old 09-17-2011, 09:51 PM   #10
If moving the needle with the car running didn't work, then you may have damaged the little servo motor that drives the needle.
Old 09-17-2011, 10:04 PM   #11
Murtaza_murti
Oh, well the needle works though. It's dropped all the way down. Sorry for going off-topic but I needed to ask, if I go for the odometer that comes with the tachometer will it be just plug and play or, will I have to do something to it in order to make it work?
Old 09-17-2011, 10:15 PM   #12
It's plug and play as long as you match your ABS or no ABS configuration.
Old 12-01-2011, 11:58 AM   #13
Murtaza_murti
Here's what I was talking about
Old 12-01-2011, 12:48 PM   #14
FuuFuu
Drives: 11 Yaris 03 Ranger 81 Escort
Another trick is to use a GPS or similar device and set it to "55" while driving. I had to do that on my truck because it did the same thing, and on occasion would stick on certain speeds.
Helps to have a friend or girlfriend do this though :p
FuuFuu is offline   Reply With Quote
Old 12-01-2011, 02:05 PM   #15
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
just buy an ultragauge. digital readout. done.
I am not a big fan of the speedo on the yaris. the ultragauge made it so much easier for me. it plugs into your obd2 port and is as accurate as your computer in your car. no adjusting, no calibrating, plug and play.
Be the change you wish to see in the world -Mahatma Gandhi-
BEEF is offline   Reply With Quote
Old 12-01-2011, 02:48 PM   #16
Murtaza_murti
How about this?
Old 10-27-2014, 10:03 AM   #17
Murtaza_murti
Bought it a while back, didn't get time to post. Had it shipped from Japan, it came off a G-selection Belta (the one with push button start and climate control).
It was plug and play.
P.S: Pardon the Pakwheels.com watermark, we have a Belta thread over there.
Old 10-27-2014, 01:00 PM   #18
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Need some installed pics!
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Speedometer Trouble jonathancash DIY / Maintenance / Service 7 05-12-2009 03:04 AM
