Old 09-07-2011, 06:40 AM   #6
Move the needle to zero with the ignition on. The speedometer is little servo motor, and if you watch it, when you power on the cluster the needle moves a tiny bit, so if you adjust it after it calibrates itself, the needle will be in the correct position.
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Yaris Central Locking Problem pbasuita UK 0 07-10-2010 03:46 AM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Speedometer Trouble jonathancash DIY / Maintenance / Service 7 05-12-2009 03:04 AM
