Old 10-15-2010, 02:05 PM   #1
Originally Posted by adam1981 View Post
Yeap, that is the connector and the direction I was counting the terminals... So, I guess my green wire is yellow and not too sure about the discrepancy on blue 20. I will recount again, but have 4 or 5 times now...
OK. I just noticed you have an 08 sedan. On that 4A-5 is yellow instead of green.
I have an 08 Sedan fuse box on my test bench, and I also see the missing wire in 4A-20 (which the EWD for an 08 sedan says should be there). Those two wires are actually tied together as a single input into the ECM, so you probably only need the yellow and that is probably the reason for the lacking blue.
Old 10-16-2010, 09:56 PM   #2
adam1981
Drives: 2008 Yaris S
Identified all of the wires and confirmed they are the right ones! Thanks for your continued help! However, they have proven difficult to tap because of the little slack in the harness.
So...I am going to have to connect all the door and truck triggers together. Got to thinking though, when I do this - the Driver Info Center is going to show all doors opened when only one actually is...
Do you know if I could place a diode in line with each of the taps before I tie them together to prevent the problem caused by just tying them all together - to maintain the integrity of each circuit? Will a diode pass the negative/ground provided by the switching?
adam1981 is offline   Reply With Quote
Old 10-16-2010, 10:01 PM   #3
Yes, you can diode isolate them to keep them separate. You would tap each door wire and insert a diode between each and the door open input on the alarm. The line on the diode needs to be towards the alarm side.
Old 10-16-2010, 10:09 PM   #4
adam1981
Got to browsing some of the other threads... Would there be a down side to tapping this pink wire for the door trigger for the alarm?
Think it would be a little easier than soldering in diodes...
http://www.yarisworld.com/forums/sho...0&postcount=14
Old 10-16-2010, 10:12 PM   #5
You'd have to try it with your particular alarm. Others have had issues with the alarm not liking the slow fade from ground to +12 when the doors are closed.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
yaris sedan remote trunk relase question pls help soon fantabulousbaby New YARIS Purchase Forum 4 08-05-2006 01:26 AM
